  • 1.  Alpha keying on cross 12
    Posted 09-19-2012 17:25
    I connected Title box with Deck link studio with SDI (key and fill key) on inputs 11 and 12 of cross 12. Now i don't know how to set inputs 11 and 12 to become alpha channel keying source and where to order what is fill key and what key signal.Any help?
  • 2.  RE: Alpha keying on cross 12
    Posted 09-19-2012 23:31
    In the config menu in inputs you select input 11 on the first knob and then you can select the alpha -- input 12 on the knob labels alpha.
    Now when you select the Keyer all you have to do is select input 11 and it will autistic ally adding the alpha.
    #CrossOver
  • 3.  RE: Alpha keying on cross 12
    Posted 09-20-2012 13:05
    Thank you!
    #CrossOver
