  • 1.  panel modules have changed, you can help
    Posted 07-23-2013 22:33
    Hi Les,
    The vision we asked to upgrade, after performing the version change maneuver in the Frame Panel, we deployed an alarm, we state: Panel Module (s) Have Changed, please go to Panel Module menu.
    You can help.
  • 2.  RE: panel modules have changed, you can help
    Posted 07-23-2013 22:46
    The panel module menu is under setup then more.
    You can upgrade them there as well as make sure they are all present and configured to a row.
    Please contact tech support at 613.652.4886 if you need further assistance so they can walk you through the process.
    #Vision
