  • 1.  Carbonite or Plus
    Posted 09-30-2016 11:06
    I'm trying to decide if I need a standard Carbonite or the Plus, is there a timing window before I need to use a Frame Synchronizer?
  • 2.  RE: Carbonite or Plus
    Posted 09-30-2016 12:44
    You have + or - a quarter line timing window. So your devices all need to have Genlock inputs. The plus also gives you colour correction and proc amp on every input. Those frame syncs are also conversion for other formats as well.
    If your looking at the Black Series then there is even more features like conversion and CC/Proc on outputs 11-22 and 3 additional MVs.
  • 3.  RE: Carbonite or Plus
    Posted 10-03-2016 08:29
    So does it vary if I'm working in SD or HD? what is it in time?
  • 4.  RE: Carbonite or Plus
    Posted 10-03-2016 13:23
    Hi James, We specify the Timing window to always be +/- 1/4 Line in all our video formats.
