  • 1.  Crossover 16 Aux 4... need help
    Posted 11-26-2012 15:54
    I have a Crossover 16 that I've updated to the latest software. I'd like to be able to change the output of AUX 4, but for some reason, right now I can't. It says it's a fixed output (or similar, I'm away from the switcher so I might not have the exact term).
    I've looked through the manual & the menus, and I can't figure it out. Is there a setting that I'm missing to be able to change the output of aux 4?
  • 2.  RE: Crossover 16 Aux 4... need help
    Posted 11-26-2012 16:25
    If it says Fixed -- that is because in the Aux Menu (under System Menu) you have assigned the output to a specific source and not left it unlocked.
    Also note that if you have the MediaWipe feature enabled this will disable Aux 4, but that does not sound like what you are seeing.
    #CrossOver
  • 3.  RE: Crossover 16 Aux 4... need help
    Posted 11-26-2012 16:29
    Perfect! That fixed everything. Thanks for your quick reply, Les!
    I had a feeling it was something simple that I was missing.
    #CrossOver
