  • 1.  Vision 16 - naming
    Posted 08-15-2013 01:56
    Not a huge deal.. But after updating our vision software to 16, I've noticed when in the naming menu, like naming a custom control for example, the "back" button is greyed out. So after naming something a user can no longer go back to the previous menu, rather you are forced to hit "home" and navigate back from there.
    Is this normal for V. 16?
  • 2.  RE: Vision 16 - naming
    Posted 08-15-2013 15:12
    You can use the up one button to gout the one level of menu.
    yes with memories you can use the memory attribute system to select the Aux buses you would like to recallwith the memory.
    yes you can also program a custom control with aux bus selections.
    #Vision
  • 3.  RE: Vision 16 - naming
    Posted 08-16-2013 04:00
    Thank you Les, I had never used the Up One button, rather only used the Back button to go back a menu.
    Was your second and third sentences meant for someone else?
    #Vision
  • 4.  RE: Vision 16 - naming
    Posted 08-16-2013 15:02
    Yup -- reading multiple posts at once and replying to them in the wrong post. Kind of funny so I left it there :)
    #Vision
