  • 1.  Glitch during splitbox custom control
    Posted 01-22-2016 02:41
    Hi-
    I'm running a 2ME Carbonite version 10.1. A few weeks ago, we upgraded the PMC. Since then, there are glitches on the DVE box sources of my splitbox custom control. The glitches appear regardless of what sources are in the boxes, and only appear while running the splitbox custom controls. I changed the Memory Recall from Effects Dissolve to Memory, and the glitches don't seem to be happening now, but I'd really like to get the movement of Effects Dissolve back. Any suggestions on what could be causing this? Sorry for long post and thanks in advance.
  • 2.  RE: Glitch during splitbox custom control
    Posted 01-22-2016 15:06
    The PMC upgrade will have no effect on your DVE that is a Panel Module Controller. Upgrade to version 11 that we have on the website currently. If the above is still happening I would then suggest you contact tech support directly to log a ticket. 613-652-4886
