  • 1.  Monitor Transitions
    Posted 07-16-2017 02:30
    I would like to use transitions with sources in our studio monitors. And if possible I would like to have a live cg on sources in monitor while on cam. Any ideas on achieving these? Using OD 12, Vision 17.3g 3ME
  • 2.  RE: Monitor Transitions
    Posted 07-16-2017 03:41
    You could use an AuxKeyer -- that does mean that you get only 1 keyer for the CG and then it is dissolves and cuts only for the BKGD. If you want wipes, DVE or more than 1 key layer then you will need to add the 4th ME to the switcher so that you can have a Fixed ME for use in this situation.
    #Vision
