  • 1.  Latching Multi DSK to a wipe or dissolve
    Posted 05-28-2014 04:19
    I'd like to be able to latch one of my DSKs to a dissolve or wipe and have it transition out instead of just cutting. I'm currently using a Vision switcher with two MLEs. Is there any way to achieve this or any workaround to get the same results using regular keys?
    Thanks for the help,
    Rory
  • 2.  RE: Latching Multi DSK to a wipe or dissolve
    Posted 05-30-2014 03:45
    It depends on the installed options on your Vision of whether or not you can transition latched DSKs.
    I would think that regardless of the installed options you would be able to do a wipe with keys transitioning on an ME with "regular" keys... but could be wrong.
    #Vision
  • 3.  RE: Latching Multi DSK to a wipe or dissolve
    Posted 05-30-2014 05:14
    Rory:
    To my knowledge: DSKs ONLY cut on and off, thus can not be latched to do a wipe transition.
    Jason is correct in his statement[QUOTE]regardless of the installed options you would be able to do a wipe with keys transitioning on an ME with "regular" keys ---- in saying that, if you could use whatever your keying with the DSK as the top layered keyer on the pgm/pvw bank then you could "latch" the keyer(s) with the background and then preform a wipe or dissolve.
    refer to the ops manual: Vision Ops Manual ( section 7 )
    #Vision
