  • 1.  Hard Reset Crossover Solo
    Posted 10-23-2018 09:43
    How to reset Cross Over Solo as its not accepting source on both the keys while using a 2 way box
  • 2.  RE: Hard Reset Crossover Solo
    Posted 10-23-2018 13:22
    Do those keys work as another key type? Can you use a self key. Set the clip and gain to zero and see the video? Is it only when you turn on DVE that you don't see video?
    #CrossOver
