  • 1.  Set Default AUTO TRANS rate
    Posted 03-26-2018 19:35
    How can I set my default AUTO TRANS rate?
    I always have 13 frames and I want to change it but I dont know how.
    My switcher is a Ross Carbonite
  • 2.  RE: Set Default AUTO TRANS rate
    Posted 03-26-2018 19:50
    That is stored as part of your RState. You can configure your switcher for exactly how you want it to be when it boots up -- or is reset -- this includes everything about it. Think of it like a default Memory. Then once you have everything the way you like it you need to store your RState. This will give you everything the way you want it. You will find this under the Reset Menu. So from the Reset Menu button have you go to the main menu. Then the page option will have a Save Rstate -- just click the button. Every show file can have it's own RState.
