  • 1.  Storing Aux Buses
    Posted 08-15-2013 05:13
    Hello, is there a way to store the setup of aux buses for the Vision Series? We just ran new Belden cables to several TVs in our studio, and they're hooked up to the I (out) card on our frame. I've tried storing the setup (like what all the outputs are) of the auxes to global store and it seems like either when we recall another store, or we shutdown the switcher at the end of the day, the setup is lost and either just the setting of the auxes, or even the Output BNCs settings are gone, and we have to go back in and set each bnc to an aux. If you can't save them to global store, can you set a custom control to change them?
  • 2.  RE: Storing Aux Buses
    Posted 08-15-2013 15:13
    you need to use your memory attributes with them memories to set what memories do or do not change the aux bus selections.
    #Vision
  • 3.  RE: Storing Aux Buses
    Posted 08-16-2013 04:13
    Yes you can set up a custom control to re-route all of your desired aux buses. Just start recording and do all your routes.
    #Vision
