I am trying to learn how to build in static transitions between sources when assembling the Custom Controls. I switch on 4 AUX Busses simultaneously, so the only way to do this seamlessly is to program everything beforehand into a Custom Control. Here's the dilemma I'm facing: I utilize the PGM bus for 1 of the 4 destinations, but have the other 3 programmed to a TripleWide Computer (inputs "Songs 1", "Songs 2" and "Songs 3 on the Switcher.) I have a Custom Control built that has the desired look, but am wondering how to program in a dissolve transition for when I want to go to the next scene. Is it possible to build in a 15 Frame Dissolve between sources (say I'm fading from inputs "Song 1" to "Cam 5") without using the PGM Bus?
