https://help.rossvideo.com/acuity/Topics/Operation/CustomControls/Special-VTR.html
Should just be Play Loop ON and Play Loop OFF commands.
Sent: 03-29-2023 15:33
Subject: EVS Loop from Acuity using VDCP
Hi Les.
What are these commands named in the SPECIAL/VTR command list?
Thanks.
Anthony Garcia
Technical Director
Sent: 10-26-2021 09:29
v9.2c is in PV and it will have the Loop for EVS and additional Play after Loop commands required .
Once out of PV it will be available for download.
Sent: 10-22-2021 15:09
I'm trying to do this exact action and stumbled upon this thread. Has this been implemented in the last 3 years?
Joe
Joe Alvaro
Production Engineering Manager
MLB Network
Sent: 07-25-2018 00:41
No when you configure the clip you can do loop. With a Custom Control you can enable loop mode from the insert event menu. Based on the server we do the loop differently. Yes we were informed of this method and will be looking into implementing it.
#Acuity
