  • 1.  Media wipe alpha channel problems
    Posted 10-12-2017 20:25
    I created a media wipe in After Effects with an alpha channel. I exported it as a PNG sequence with an alpha channel using Media Encoder. When I load it into Media Manager it lists the file as "Alpha Channel: yes" BUT when we run it there's no alpha channel. Any ideas?
  • 2.  RE: Media wipe alpha channel problems
    Posted 10-12-2017 23:09
    What Channel did you load it into? Are you using the MediaWipe transition type?
    https://www.dropbox.com/sh/w4fyul2tpiznj73/AADe8Qaum1ElGZf-x-lsS6oNa?dl=0
    Above is a link to a wipe that we have used for Demos and training. Give it a try. Also if you could post a link to your file I can have a look at it.
  • 3.  RE: Media wipe alpha channel problems
    Posted 10-13-2017 14:51
    Thank you! I've downloaded that folder and we're going to test it here in a minute. In the mean time, here's the media wipe we're having trouble with:
    https://www.dropbox.com/sh/xh97eu0gg3hqv6b/AACAu-VQuo9pPchFZntETKXta?dl=0
    We play it out of M2, which is what we've played all our other media wipes from with no issue.
  • 4.  RE: Media wipe alpha channel problems
    Posted 10-13-2017 15:07
    The file has the "alpha channel" in it but it is not a matching Alpha it is just a full frame white for all the frames. So looks like it was built wrong in After Effects.
