  • 1.  DATALINQ with Material
    Posted 08-29-2012 13:25
    Hi guys,
    I want to set up a material to be bound to a datalinq source.
    Text fields are updated,so the server connection is running.
    What does Xpression expect to use a datalinq for a logo.
    I used a complete datapath like: d:/Media/xy.tga
    but it never dates uo.
    What am I doing wrong?
  • 2.  RE: DATALINQ with Material
    Posted 08-29-2012 13:44
    Tom, did you try back-slashes instead?
    #Vision
  • 3.  RE: DATALINQ with Material
    Posted 08-29-2012 14:21
    I tried. no change ;-(
    #Vision
  • 4.  RE: DATALINQ with Material
    Posted 08-30-2012 19:10
    Tom,
    If you copy and paste the file path that you are specifying in the data source to the Windows Explorer (the file explorer) address bar, does the image appear?
    The file path must be exactly correct.
    #Vision
  • 5.  RE: DATALINQ with Material
    Posted 09-11-2012 18:16
    Tom, I've had some experience with this in building WREX's election graphics. We use a base template with empty quads for headshots, then have "placeholder" materials set to those. The data coming through the datalinq is determined by us per candidate (i.e., Cheri Bustos will have the data CB-01). We then have a file called CB-01.png in a folder within the XPression project folder.
    Using a fairly basic script, it grabs the data, searched up the file path to find that image, and assigns it as a shader to the "placeholder" material.
    The trick was, we needed an empty material (we used 100% transparent .png's) assigned to each quad in order to get it to work.
    Feel free and contact me if you have any questions. djensen@wrex.com
    #Vision
  • 6.  RE: DATALINQ with Material
    Posted 09-11-2012 19:50
    There's is also another solution, by using the "Name" of the candidate as a base for the materials Image. I usually use a folder with all candidates headshots located on the XPression system. What you do is create 2 variables, one for the name text object and one for the material. The script will then use the name field set in the sequencer or MOS environment then add the .png file extension to it and then retrieve that image from a specified folder. As long as the images are named exactly as the name will apear then you'll have your material shown properly.
    Neil Hopley
    Wireframe Group
    www.groupewireframe.com
    514-261-4380
    #Vision
  • 7.  RE: DATALINQ with Material
    Posted 10-01-2012 22:16
    Update with the script version we use:
    dim PicTag as xpTextObject
    dim Pic as xpBaseObject
    dim PicMat as xpMaterial
    dim PicShad as xpBaseShader
    dim FilePath as String
    dim i as Integer
    For i = 1 to 4
    Self.GetObjectByName("Pic Tag " & i, PicTag)
    FilePath = Engine.ProjectPath & "Election Headshots" & PicTag.Text & ".png"
    Self.GetObjectByName("Pic " & i, Pic)
    Pic.GetMaterial(0, PicMat)
    PicMat.GetShader(0, PicShad)
    PicShad.SetFileName(FilePath)
    Next i
    #Vision
  • 8.  RE: DATALINQ with Material
    Posted 10-04-2012 21:32
    I usually work with datalinq textures. The datapath applied to an excel cell or a .txt
    But take care that you will never see a refresh in layout mode or with Preview when you change the datapath in your excel or txt.
    You will see when you send the take item to air, not before.
    #Vision
