Hi there,
Firstly a comment, I've found this forum to be a tremendous resource for learning the Carbonite...Well done Ross Forums.
Here's where I'm needing some help, I'm working a 9 day event on a Carbonite. A day ago when I double pressed a source the on panel menu would go to the Proc Amp and Colour Correction options, it's no longer doing this. Is there a menu setting where this may have been inadvertently turned off?
It's seems the live assist is no longer following on the dashboard either.
