Alright, then maybe you can help me with one of my CCs.
1. State PGM: I'm setting up 4 different DVE-Keyers, which mainly include position, size and masks.
2. Hold
3. Effect Dissolve: Doing something irrelevant on a different ME.
What I want to achieve is, that I am able to manually adjust the position and size of the keyers within the mask during the hold. Then I want the effect dissolve to take place and leave the key parameters as I've just set them up.
Before storing the effect dissolve state, I greyed out all MLE 1 keyer parameters in Live Assist - Memory - Store. However if I do the effect dissolve, the keyers dissolve back to what was initially stored in the State PGM (and what is maybe also stored in the effect dissolve?). Do you know why?
Marc
