  • 1.  Custom Transition Malfunction
    Posted 05-16-2017 00:09
    I have built multiple full screen key transitions that have been working fine until now. They are supposed to cue up the video clip transitions from X-Clips and after a 5 frame pause simultaneously roll the clip and turn the X-Clips key on then auto transition whatever is in PV then after 1 second turn the key off. The key source (X-clips) has motion but the key itself does not move at all on the screen - it just turns on and off. However now it (the key) is starting off screen then sliding in from the right but if I run the custom manually step by step it works fine (no slide). This has occurred with all similar transitions out of the blue and prior to this happening they have been running fine for months - I am wondering if anyone has any ideas as to what may be happening. FYI I have restarted both the switcher and the X-clips just in case but to no avail.
    -=Mike
  • 2.  RE: Custom Transition Malfunction
    Posted 05-16-2017 17:28
    And fortunately is was something fairly simple - someone had gone into my X-clips server and changed the playback method of the specific server that provided the media clip to push the clip on-screen. Once it was changed back all the effected customs (that used that server) went back to normal playback. PROBLEM SOLVED
    #Acuity
