  • 1.  Keyer in Carbonite
    Posted 05-09-2015 22:34
    Hey Everyone,
    For some reason when ever I load a bug into my media store it looses its color. Do you know why it is doing this? The alpha is there, but the color has turned opaque. I can put the bug in an editor and it works fine. Have any thoughts on why this is? Am I using the right keyer?
    Appreciate any advice,
    Ryan
  • 2.  RE: Keyer in Carbonite
    Posted 05-10-2015 01:38
    Are you using Auto Select Key type?
    Do you have an example of the File your loading that I can download and look at?
    Sometimes the issue is that PS or AE is adding "white" to the Fill no Black so you can't do an Additive Key either.
  • 3.  RE: Keyer in Carbonite
    Posted 05-12-2015 16:13
    We are doing an additive key I believe. Here is a link to the file. http://we.tl/zUZkpYEoBj
    Thanks again for your help?
  • 4.  RE: Keyer in Carbonite
    Posted 05-13-2015 18:38
    We figured it out. It turned out that we were putting the fill in the key channel. We thought the key and fill was M1-M2 and M3-M4. It turns out that it is M1-M3 and M2-M4.
    Thanks,
    Ryan
