  • 1.  Solo Custom Viewcontrol Bus select
    Posted 10-18-2016 19:57
    In a Custom Viewcontrol Panel, there are bus select buttons underneath the Multiviewer windows so you can select whether you are changing ME Preset, ME Program, MiniME 1 PGM etc. Can I create a similar button that allows me to change what is being fed to an AUX output? Also, can I then select ME Program or MiniME 1 PGM to go to that AUX output from Viewcontrol?
    Thanks,
    Jeff
  • 2.  RE: Solo Custom Viewcontrol Bus select
    Posted 10-18-2016 20:16
    Hi Jeff, No you don't currently have the ability to change any of those buttons. Further the Windows for sources is how ViewControl figures out what the source needs to be -- Therefore you would need to assign the MiniME to that Window.
