Tony, Here is the instruction for camera control. To access focus and iris you need to press next in the menu control area...
To Manually Control the Camera Head 1. Press the source button for the camera you want to control. 2. Use the positioner, or the knobs, to adjust the pan, tilt, and zoom of the camera. "¢ Pan "“ move the camera head left or right "¢ Tilt "“ move the camera head up or down "¢ Zoom "“ zoom the camera lens in or out 3. Press NEXT. 4. Press the Focus knob to toggle between auto and manual focus. "¢ Use the Focus knob to manually focus the camera lens in manual mode. 5. Press the Iris knob to toggle between auto and manual iris. "¢ Use the Iris knob to manually open and close the iris in manual mode.
Are you using a MOXA IP to Serial protocol converter and made sure that the settings for the serial port match the camera settings? We have not seen any erratic behaviour in control from the panel.
Nigel
