  • 1.  Carbonite/Graphite: Chroma Key Fly
    Posted 12-24-2017 05:51
    I'm not really trying to do a Chroma Key Fly effect but I am trying to build a chroma key effect that would allow my chroma key to be moved or DVEed across the background. Essentially, I am trying to take the full 16x9 chroma camera shot, chroma key it and then shrink it down over a background.
    Is there a way to do this? or fake it?
    I found some similar posts about using MiMEs and split keying with a ME PVW bus while Show Key is lit. However, I'm using the Graphite and don't know if I am actually getting the full bell and whistles Carbonite capabilities.
  • 2.  RE: Carbonite/Graphite: Chroma Key Fly
    Posted 12-24-2017 11:43
    You can absolutely do this Fedij, is very easy. First setup the chroma key as usual, then hold the CHR KEY button and press DVE. Now the chroma key can be resized and positioned with the DVE.
    Merry Xmas.
  • 3.  RE: Carbonite/Graphite: Chroma Key Fly
    Posted 12-25-2017 02:42
    Thanks for the response and the tip! That worked! I think I couldn't get that to work because I didn't have access to the panel.
    Happy Holidays!
