Hi Rich,
Is this a 2 keyer system or was it upgraded to 4 Keyer? If it is a 2 Keyer then you should use software 14.0 as the extra features that were in 14.1 only apply to a 4 keyer Vid Proc.
There was a bug found about the implementation of the individual keyer transitions for the 4 keyer Vid. We are working on releasing a version of 14.1 that addresses these issues for the 2 Keyer Vid -- however unless your OverDrive or a 4 Keyer Vid then there is no real reason to be on 14.1 over 14.0.
#Vision
