  • 1.  MLE-Store Preview
    Posted 09-24-2012 16:59
    Is there a way to put MLE-Stores into the multiviewer or to output them to a monitor? When I go into the menu to change the multiviewer or outputs, I see global-stores, but not MLE-stores.
  • 2.  RE: MLE-Store Preview
    Posted 09-25-2012 15:09
    Hi Matt,
    The MLE Stores are internal to the MLEs and do not hit the XPT card. That is why they are only accessible in the MLE.
    Now if you have the 4 Keyer Video Process Card (not the legacy 2 keyer version):
    In version 14.1 we did add a feature though that would allow you, if your not using the Clean Feeds for anything, to set the Clean Feed outputs of the MLE to send the MLE Stores back to the XPT instead of the Clean Feeds. This will get you a Maximum of 2 of your MLE Stores into the XPT and you will now be able to access them like a global store and even put them in the MultiViewer.
    #Vision
  • 3.  RE: MLE-Store Preview
    Posted 09-25-2012 15:16
    Oh and Matt
    The menu is Installation--Outputs--Clean Feed
    Then you can pick the MLEs and the Clean Feeds you want to set to MLE Stores instead.
    #Vision
  • 4.  RE: MLE-Store Preview
    Posted 09-25-2012 15:26
    Thanks Les. I guess this gives me a good reason to upgrade.
    #Vision
