  • 1.  Issue with Key Memory
    Posted 10-12-2017 01:51
    Hi all,
    Thanks again for all the help with my previous queries. I have another issue I'm struggling to find an answer to.
    How does Key Memory work? We've recently had to re-map our Switcher some, and one of the button inputs (on the Shift Bus) intended to be Keyed will not. From what I can tell, it's missing the Key Memory, as the graphic we're Keying does in fact have a built-in Alpha Channel.
    I've tried to include a snapshot of the error message I keep getting. The Switcher keeps asking for the Alpha to be defined but I don't know how to do that.
    Thanks for any and all help, folks. It's appreciated!
    ~Sean
  • 2.  RE: Issue with Key Memory
    Posted 10-12-2017 11:54
    You need in Source configuration to map the Auto Key configuration so that it knows which BNC is the Key Channel. So Installation - Source Configuration - Auto Key Setup.
    There you will be able to use the first knob to select the source for the Fill then use the second knob to select the Alpha/Key BNC. Now your pair will be complete.
    #Vision
  • 3.  RE: Issue with Key Memory
    Posted 10-12-2017 16:56
    I just worked through this with your advice and now it works! :D I am beyond excited I understand how to do this now. Thank you so much for all your help and expertise, sir!
    You guys at Ross are amazing!!
    #Vision
  • 4.  RE: Issue with Key Memory
    Posted 10-12-2017 23:29
    Glad we could Help!!
    #Vision
