  • 1.  Crossover Multidisplay Glitchy problem
    Posted 12-16-2011 15:59
    We have a Ross Crossover 12 that I did an upgrade to sometime last year. Using the PV out we have the multi-display capability which works well except for some glitchy lines that flash through the video intermittently. This does not affect any of the actual outputs but only is on the PV out for monitoring. Any ideas on how to eliminate this? It's just a little irritating.
  • 2.  RE: Crossover Multidisplay Glitchy problem
    Posted 12-16-2011 16:04
    Hi Zane,
    I suggest you contact tech support at 613-652-4886. If you see lines in the MultiViewer output there is a chance that there is an issue with the unit and they can help you fix this.
    #CrossOver
