Paul/Les how exactly did you get dashboard panel button configured to work with even FTB?
Trying to set up a similar scenario to fire off CC from a networked PC on the same network as the frame.
Ross Vision 1 is using v.16.1d, and Dashboard 6.2 beta
Com Port is set to: RTalk-IN, Network TCP, IP address, Port 7788 on the Vision 1.
On Dashboard our frame is not detected automatically or manually added or visible in the basic tree, but each panel button we created is configured to use Rosstalk using the frame IP address.
Am I missing something? Any help would be greatly appreciated.
Tim
#Vision
