  • 1.  MiniME
    Posted 06-28-2014 11:29
    I just upgraded my software version to 8.03 to enable MiniME, but I cannot find any documentation on how to use the MiniMes. Do I need Dashboard to use them?
  • 2.  RE: MiniME
    Posted 06-28-2014 12:04
    Dave,
    There are instructions in both the setup and operations manual under resource mode selection. Here is a link to a quick guide on setting up the MiniME's that might be helpful. You don't need dashboard as everything is setup from the panel, Dashboard is a great help though and I would highly recommend using it if you are not currently.
    https://www.dropbox.com/s/0bpn1ccu7okpu3f/MiniME%20Setup.pdf
    Nigel
  • 3.  RE: MiniME
    Posted 06-28-2014 17:33
    Thanks. I guess i was looking for a dedicated section in the manual.
