  • 1.  Locked keyer with alpha on keyer 1 and 3
    Posted 01-26-2014 14:40
    When testing the keyer todo "still capture", we have locked the keyer 1 and 3 with e media store M1 and M3 ( auto select mode set).
    How can I unlock the 2 media store when using the "auto select" mode
  • 2.  RE: Locked keyer with alpha on keyer 1 and 3
    Posted 01-28-2014 03:00
    Hi Stephane,
    I don't think I understand your question correctly. When you do an AutoKey you are doing a Linear key that uses Media 1 for fill and Media 3 for alpha. If you just want to do a luma key you can select Self key. If you want to do a split key then hold down the Auto Select button and then select the new Alpha source on the Key bus while held down.
