  • 1.  Where did the Alpha go?
    Posted 01-28-2014 13:00
    The students here at University of Stavanger is trying to produce some tga-sequences to put into Media player in Carbonite, and some other for use as Video material in XPression.
    It seems rather impossible to get the alpha of these sequences to be detected in either of the target machines even though everything seems ok in the After Effects end of the job, IE exported as RGB+alpha.
    Are there any considerations we might be ignorant to when making tga's from After Effects that causes this?
  • 2.  RE: Where did the Alpha go?
    Posted 01-28-2014 13:57
    Figured out - 32 bit!
