  • 1.  Carbonite Switcher question....
    Posted 04-09-2014 15:54
    We use a Carbonite switcher at our church for Saturday and Sunday services.... However, I work on a Ross Vision switcher and know that we have a source clock that is tied into the switcher. I don't know enough about the Carbonite, so I have to ask. Does the Carbonite switcher have a source clock within it that can be easily accessed?
  • 2.  RE: Carbonite Switcher question....
    Posted 04-11-2014 18:47
    We do not have a count down timer in Carbonite like there is in Vision.
  • 3.  RE: Carbonite Switcher question....
    Posted 04-21-2014 18:25
    The closest thing you have is a regular time-of-day clock that can be turned on/off, assigned custom colors/sizing & positioned anywhere on the multiviewer output.
  • 4.  RE: Carbonite Switcher question....
    Posted 06-26-2014 19:25
    With regard to the time of day clock, how do you get the system time to be accurate?
    Thanks for any help.
  • 5.  RE: Carbonite Switcher question....
    Posted 06-26-2014 19:39
    I'm not in front of the console right now but I believe it's SYSTEM --> MULTIVIEW --> EDIT CLOCK
  • 6.  RE: Carbonite Switcher question....
    Posted 06-26-2014 19:42
    Thank you.
    I did try that, however, the only parameters I could change were to turn the clock on/off, adjust color, sizing and position. There did not appear to be a way to set the correct time there.
  • 7.  RE: Carbonite Switcher question....
    Posted 06-26-2014 19:45
    OK I'll walk over to the control room and take a look, I can confirm it is possible because I've done it before.
  • 8.  RE: Carbonite Switcher question....
    Posted 06-26-2014 19:49
    OK it's MENU --> CONFIG --> NEXT --> CLOCK.
    Toggle the 12/24 hour mode then hit EDIT to set the actual time.
    Cheers!
  • 9.  RE: Carbonite Switcher question....
    Posted 06-26-2014 19:54
    Many thanks, Tyrone!
