  • 1.  Menu Buttons don't work
    Posted 11-21-2013 17:42
    The menu buttons on the Ross Carbonite I am using will turn but they will not push down to activate the menu. Has anyone else had this problem?
  • 2.  RE: Menu Buttons don't work
    Posted 11-21-2013 17:54
    Sounds like the Knobs have moved down the shaft too far.
    You need a .5 Allen Key and you can adjust the set screw. Lift it up a little and then you can set it again. Now it should be fine.
  • 3.  RE: Menu Buttons don't work
    Posted 11-21-2013 18:18
    Thanks, I will try that today
  • 4.  RE: Menu Buttons don't work
    Posted 11-22-2013 07:09
    That was it, raising the knobs on the shaft worked.
    Thanks again
    -Brian
