  • 1.  Lock MLE Store
    Posted 01-17-2012 22:05
    Any way to lock the MLE store function so nobody else can change or overwrite the memories?
    Thanks Les.
  • 2.  RE: Lock MLE Store
    Posted 01-17-2012 23:44
    Hi Ryan,
    No there is no way to "Lock" a memory. I would suggest saving your settings to USB so that you can Recall your Memories from that file if they are changed.
    on the USB you can save SET0-SET9 so essentially 10 sets. What is a little know secret is that if you go into the /switcher directory you can make new directories or rename saved sets to another name. once there is a directory created or renamed it will show up in the menu -- so essentially you have unlimited Switcher Setups that you can have on a single USB.
