Hi Jim. You can have different colours on the Mini MEs if you select a colour scheme that has those with different colours. To set the colour scheme (from the setup manual p. 34):
1. Press MENU > USER > Scheme
2. Press NEXT
3. Use the Load knob to select the color scheme you want to use.
If you have created custom color schemes, you can select it from the menu.
4. Press the Load knob.
5. Press the Confirm knob.
Personally, I like the Neon scheme. It colour codes the source selection buttons based on if you have keyers, auxes, or customs selected, so you know which mode those buttons are in. Also, the colours of the two MEs and MiniMEs are significantly different to the source selection buttons (when using auxes or customs) so it's more obvious. It's also nicer looking than some of the others that have features like that.
