  • 1.  Crossover Mask Key
    Posted 08-17-2012 15:51
    I am using a mask key in Keyer 2 and the mask will not stay when the Key is selected. I can watch the percentages changing when it is selected and on air the mask keeps on getting smaller and smaller. Is this an user, hardware, or a software issue?
  • 2.  RE: Crossover Mask Key
    Posted 08-17-2012 17:35
    Sounds like there might be a calibration issue.
    If you do a DVE Key does the DVE do a similar response?
  • 3.  RE: Crossover Mask Key
    Posted 08-17-2012 17:51
    Yes that was the issue the joy stick needed calibrating. Thanks for your help
