Hey Les,
We tried your suggestion and discovered some weird behavior. Steps taken:
- Device created - RossTalk, generic driver, IP of the Carbonite frame
- CC created to cut P/P
- GPI 1 set to run that CC
- CC created to run GPI 1 on the created device
The CC to cut P/P works when pressing the CC button on the TD2 and when clicking the CC from Shotbox.
The CC to run GPI 1 does not work from either the TD or the Shotbox. BUT, pressing "Run Event" from within the CC editor does work.
So the CC to run the GPI has one line of instructions which works if you Run Event, but not if you run the CC.
Further, when we opened our old Hyperdeck CCs, running the "play" event directly works, but running the whole CC does not.
See video.------------------------------
Tom Wade
Sent: 01-04-2023 18:50
Subject: Custom Control for HyperDeck
RossTalk defaults to sending over TCP .. adding it to send UDP was an addition and it is in version 7.1
Easy test is to setup a RossTalk device that sends back to the switcher .. Send GPI 1 to the switcher .. setup GPI 1 to Run A custom control. Have that custom control just CUT on program.
now run that CC does it cause the switcher to cut?
Sent: 01-04-2023 16:00
Thanks for your help on this, Les.
I remember a parameter for transfer protocol on the device setup when setting up a device on the physical TouchDrive panel, though that was before the addition of the Devices page. I'm just spitballing, remembering issues with UDP vs TCP in the past, something about the Carbonite not sending RossTalk over TCP?
Tom Wade
Sent: 01-04-2023 14:49
Can you post what version you upgraded to?
Screen shot of the status page would be fine. Also what are you missing? I don't think the transfer protocol was there (my unit has a version that is not yet out of PV that i used for the screen shots.)
Sent: 01-04-2023 14:26
Removed the device and remade it with no luck. We're not using Roll Clip for this, just a CC that sends a RossTalk message to the device with the command (play).
Tom Wade
Sent: 01-04-2023 14:21
maybe try removing the device and adding it back again? Also make sure if you are using the Roll Clip function to set the value to something other than 0 apply those changes.. then switch it back to 0 and apply those changes..
Sent: 01-04-2023 14:07
Hello all,
We're having some trouble with our previously-working CCs. We had been using the method Aaron described in Post 9 of this thread successfully. We updated our Carbonite Ultra to the latest version over the holiday break.
I created a CustomPage and made a button that sends a TCP message (string) to the Hyperdeck, and that works.
Did something change with a recent update that would have broken the old method? I notice that the Transfer Protocol is no longer visible in the device settings - could it be a TCP/UDP issue?
Tom Wade
Sent: 01-04-2023 10:41
Wow .. that is some really really old software on there :) ....
Yes you would need to upgrade but good news is that it is complimentary and available for download on the website.
If you are going to make that Jump though I recommend you set aside some time to make sure that all of your settings, memories and Effects come through correctly...
Sent: 01-04-2023 08:32
I assume I have to upgrade the mixer then?
I'm running 9.1.0.11223 at the moment.
Tue Sandbæk
Director / TV-Technician
TV SYD
Sent: 01-04-2023 08:25
RossTalk is the same on All of the Carbonite Switchers. You can insert the custom events in a similar manner.
Sent: 01-04-2023 04:04
Is the feature with RossTalk commands from Carbonite a software og hardware specific thing?
Have an older Carbonite+ would I be able to do the same here?
I have testet on our Carbonite Black, there it works.
Tue Sandbæk
TV SYD
Sent: 05-10-2021 05:07
Hi Kevin, yes there is now a more straightforward method to trigger a BMD Hyperdeck from a Carbonite. By inserting a RossTalk command into a Custom Control, we are able to send commands from the Carbonite to a Hyperdeck.
The list of commands available is on pg66 of the Hyperdeck manual.
https://documents.blackmagicdesign.com/UserManuals/HyperDeckManual.pdf?_v=1585983610000
First, setup a generic RossTalk device outlined on the following page.
http://help.rossvideo.com/carbonite-device/Topics/Devices/RossTalk/RossTalk.html
- You will need the IP address of the Hyperdeck and port number 9993.
Now go to Custom Control editor > Devices > RossTalk (Generic). You are able to send a custom command to the Hyperdeck which was setup in the prior step.
Aaron
Sent: 05-10-2021 01:56
Hi Les,
I know this thread is old and wondering if any update has been made for the workflow of a custom control on a carbonite to recall clips, engage/disengage loops, play/stop etc on a Blackmagic Hyperdeck mini. If I interpret the documentation in the threads, I need to connect the hyperdeck mini to a computer running dashboard, and that computer also connected to the carbonite. Use panel builder to create buttons that associate clip IDs / transport controls to GPIs.
Usually working on Ross Carbonite Multi-media but also on the newer ultra frames. I am about to purchase the Blackmagic Hyperdeck mini with the intention of using it for background loops and key/fill animations and to be triggered by CC's from the carbonite panel. I wanted to know what to expect prior to going down this road.
-Kevin
Kevin Tokunaga
Sent: 02-06-2015 20:05
Hi All,
Here is the link to the video. It expects that you have first gone thru the DashBoard U example first.
DashBoard U link:
http://www.rossvideo.com/control-systems/dashboard/dashboard-u/video-tutorial-304.html
Carbonite Link
http://youtu.be/xrSm80JP0Ns
