  • 1.  number 3 tally light
    Posted 01-19-2012 09:15
    hi, we're using carbonite 2me switcher, our problem is the number 3 taly light is intermitted while the rest tally light are not, we've check all the tallylight connectors and we found out there's no loss connection... can you please help us.... thanks
  • 2.  RE: number 3 tally light
    Posted 01-20-2012 16:09
    Hi Jeff,
    you should call Tech Support at 613-652-4886. The will be able to support you, and if determined to be hardware issue work on getting it taken care of.
