hi
i have a Carbonite MM , software version is 11.0.1
the issue came up when we are testing internal reference and SDI-FS.
the input source is 59.94i format
the switcher mode is 29.97 and 3G
output required 29.97p
in the 3G mode, we could find the Line doubler option with SDI-FS in the configure input
but in the 29.97 mode, there is no Line doubler option.
as i know, Line doubler can change interlace signal to prograssive signal.
is there a way to make a final output format to 29.97p without any other external devices?
we want to use only Carbonite.
