  • 1.  RossTalk XPT command with Preview Bus
    Posted 10-17-2014 22:15
    Carbonite Plus Version: 9.1.0.11223
    I was messing with the RossTalk with the Carbonite over ethernet and for some reason it looks like the 'XPT' command works for the program bus for each ME, but not the preview bus.
    The following command works:
    'XPT ME:1:PGM:IN:6'
    It hard cuts to inputs 6 on ME1
    but the following doesn't:
    'XPT ME:1:PV:IN:6'
    This doesn't change the preview to input 6 for ME1. It seems to do nothing.
    I'm pretty sure I'm following the syntax correctly, unless I'm missing something in the documentation.
    I was planning on using this for an upcoming show next week, but seems like it might not be possible at this rate.
  • 2.  RE: RossTalk XPT command with Preview Bus
    Posted 10-17-2014 22:28
    Nevermind. You can close this thread.
    I figured it out. It's not 'PV' it's 'PST (for Preset bus). The documentation is wrong in the 9.1 RossTalk Commands PDF.
  • 3.  RE: RossTalk XPT command with Preview Bus
    Posted 10-17-2014 23:47
    The Doc is not "wrong" it is showing you how to select an ME PV as a "source" on a Bus.
    It does not list the background buses for Bus assignments.
    It is confusing -- will try to get it updated for version 10.
  • 4.  RE: RossTalk XPT command with Preview Bus
    Posted 10-18-2014 13:57
    Ah! I get it now. Thanks for the clarification.
