We have a Carbonite 2M (software version 6.2) and are planning to record programs with 3 or 4 cameras on a green screen, with separate backgrounds (from the media stores) for each camera. I want to set up custom controls so that I only need to push one button per camera to load it all up in preset. I was shown how to do it, and I got it working once, but for some reason, I can't get it to work anymore, even doing it without using the customs.
What happens is, Key 1 takes CK1, which is fine. I cut that to program and then set up the next key (key 2). That takes CK2, which is also fine. I can switch between those two angles without any problems. The issues start when I introduce a third angle. For some reason, when Key 2 is on program, and Key 1 is on preset, Key 3 steals CK2, thus taking Key 2 off completely (I have them set to float). Setting it to ask is no good because as soon as I confirm, the same thing happens (understandably). Even when I press the Bkgd button in the next transition area before pressing the next key sel button, it still happens (even though CK1 is no longer in pgm or pst).
I have set the MLE store to no recall for all keys and their attributes (this was what I was told to do when it was shown to me). I've even tried doing the same with transition and next transition. MLE recall is all set to recall for these (maybe that's the problem?).
What should I do to get this to work again?
Thanks,
James.
