I'm experiencing an issue since upgrading from version 12.0 to version 12.4. I did a straight upgrade, so I don't know if that's the problem, or there's a bug. Basically, any devices that we have attached to an input does not get triggered when we switch to it with roll clip turned on after boot up. It worked perfectly before the upgrade. To get it working, each time I start the Carbonite up, I have to go into the inputs menu (on the panel, because I can't see where to set this in Dashboard), and reselect the appropriate device. The setting is there on start up, but it doesn't do anything until I reconfigure it. This reminds me of an identical problem I had with GPIs back on version 7.1.
Is this a problem with my upgrade path, or is this a bug?
James.
BTW, the device I'm using is a RossTalk device.
