  • 1.  Tally Rating
    Posted 09-18-2013 01:03
    The Carbonite setup manual has the following information about the Tally port:
    Input Voltage: 24VAC(rms)/40VDC
    Max Current: 120mA
    Impedance:
  • 2.  RE: Tally Rating
    Posted 09-18-2013 06:45
    Hi James,
    It is indeed a simple contact closure. The data refers to the maximum ratings for voltage and current that the switch relay contacts can handle.
    These ratings well exceed typical tally requirements.
    I hope this helps.
    Nigel.
  • 3.  RE: Tally Rating
    Posted 09-19-2013 22:36
