  • 1.  Can I apply a mask to rolling text?
    Posted 07-04-2012 01:01
    I'm attempting to roll credits at the end of a show, but need them to fade-in as they scroll up from the bottom and fade-out before they reach the top of the screen. I'd normally create a feathered mask to do this (in AE), but can't work out how to apply an image mask (basically a blurry box image) to my rolling text.
    Any ideas?
  • 2.  RE: Can I apply a mask to rolling text?
    Posted 07-04-2012 05:24
    Create a material and use a feathered targa or png.
    On layer one of your material, go to blending, source factor=zero.
    Apply this to a quad and use this object in your Scene group. Make sure it's Z position is greater than your crawl text.
    This should get you the look your going for.
  • 3.  RE: Can I apply a mask to rolling text?
    Posted 07-05-2012 01:26
    Thanks Gregory,
    I should've mentioned that the background wasn't black. (It was a looping texture)
    In the end i made 2 quads - one with the looping texture as a background, and the other with a feathered hole in the middle of the looping texture.
    Then i set my rolling text to 'render priority normal' so it sandwiched between the layers.
    Looks just like a feathered mask.
  • 4.  RE: Can I apply a mask to rolling text?
    Posted 07-10-2012 03:11
    Is there no way to "group" a quad with a mask material attached to it with a number of other quads, and have that mask only affect the contents of that grouping?
    Currently using the solution Anthony found, it works in most instances.
  • 5.  RE: Can I apply a mask to rolling text?
    Posted 07-10-2012 03:44
    Maori, in the current 3.x versions, no. This is going to be a V4 feature.
  • 6.  RE: Can I apply a mask to rolling text?
    Posted 07-10-2012 16:59
    V4 that we are waiting for !!!
  • 7.  RE: Can I apply a mask to rolling text?
    Posted 11-01-2012 11:20
    Is this option already added in the current version? Or are we still using the 'solution' Anthony provided us?
