Hi John, There are a few products out there that will burn in Time Code/ Time-of-day into a video source, which could then be used as a clock. However, it would be less expensive to mount a clock next to the display I suspect.
Check out ESE, they make a lot of inexpensive timecode and time clock devices.
Nigel
