  • 1.  Can we use MediaWipe function in Carbonite 4K mode?
    Posted 02-16-2016 11:05
    A customer would like to use Carbonite Black for Sports events.
    They like the MediaWipe function in HD mode.
    If not, do we need to use XPression for the MediaWipe transition?
  • 2.  RE: Can we use MediaWipe function in Carbonite 4K mode?
    Posted 02-16-2016 11:08
    BTW, there are 8GB storage inside Carbonite, is it shared by two MediaStores dynamically? or 4GB for MediaStore 1 and other 4GB for MediaStore 2?
  • 3.  RE: Can we use MediaWipe function in Carbonite 4K mode?
    Posted 02-16-2016 14:38
    HI,
    In 4K mode you will not be able to do a MediaWipe as there are not enough channels (you would need 8 channels 4 Video and 4 Alpha). You would need to use an XPression 4K or similar device to supply enough channels of Video and Alpha across the entire raster (so full 4K with 4 Video and 4 Alpha connections).
    There is 4 GB of Media 1/3 and 4GB for Media 2/4
  • 4.  RE: Can we use MediaWipe function in Carbonite 4K mode?
    Posted 02-18-2016 06:45
    So, I cannot load a Targa sequence in 3840x2160 resolution to M2?
  • 5.  RE: Can we use MediaWipe function in Carbonite 4K mode?
    Posted 02-19-2016 17:04
    No you can not -- the Media stores are a 1080 Raster. In 4K mode your doing Quadrant based switching.
