Hello Isaac,
With one hundred memories available per setup, might I suggest a different method to storing and recalling memories.
If you go into the memory recall, set EVERYTHING to based on how the memory is saved. Be sure to scroll through each setting for key types AND sources.
When you build a memory, you can then choose, specific to each memory how you want the memory to recall.
This includes, memAI, EFF DISS and PGM.
If you save your memories this way, plus set all your recalls based on how memories were saved, then the custom controls used to recalling memories should recall exactly what you want.
