Cadbonite Media Manager greyed out
  • 1.  Cadbonite Media Manager greyed out
    Posted 02-02-2015 19:44
    Hey anyone know why all the controls in the media manager would be all grayed out and permit no access to even the internal media?
    I can do nothing in the media manager but all other controls in Dashboard are working fine.
  • 2.  RE: Cadbonite Media Manager greyed out
    Posted 02-02-2015 20:15
    So just to add a little more detail, i just upgraded from 9.1 to 10 and no change. still no access to the media manager interface.
  • 3.  RE: Cadbonite Media Manager greyed out
    Posted 02-02-2015 20:50
    Hi Brian,
    It's actually a Web UI and launching a Browser. It is using your default browser an so you probably need to upgrade Internet Explorer to version 10.
  • 4.  RE: Cadbonite Media Manager greyed out
    Posted 02-03-2015 12:57
    Thats interesting. the default browser on our machine is Chrome. Does the UI require IE?
  • 5.  RE: Cadbonite Media Manager greyed out
    Posted 02-03-2015 15:49
    Hi Brian,
    I think if you have IE installed it is what Windows uses under the hood. Can you update to IE 10 and then try again?
  • 6.  RE: Cadbonite Media Manager greyed out
    Posted 02-03-2015 17:11
    So we decided to upgrade the machine. It was an older slower machine with XP. We are changing to a faster newer machine with Win 7. I ll let you know how it goes.
  • 7.  RE: Cadbonite Media Manager greyed out
    Posted 02-11-2015 19:58
    hey. got the same problem.
    system was rebooted before and i even tryed a fresh formated stick.
    got no window on dashboard webbrowser chrome / iexplore
    it was working before i restarted the system
  • 8.  RE: Cadbonite Media Manager greyed out
    Posted 02-11-2015 20:21
    what happens if you open a web browser and then enter the switchers ip?
  • 9.  RE: Cadbonite Media Manager greyed out
    Posted 02-11-2015 21:07
    the same. it opens up the url but you only see ross on the top and thats it.
    the m1 m2 m3 m4 buttons and all the others things are not there. just empty window
  • 10.  RE: Cadbonite Media Manager greyed out
    Posted 02-11-2015 21:25
    try rebooting the switcher but this sounds like a PC browser issue
  • 11.  RE: Cadbonite Media Manager greyed out
    Posted 02-11-2015 21:53
    i cant be. i have 2 different pcs - both of them show the same problem. switcher is rebooted 2 times already.
  • 12.  RE: Cadbonite Media Manager greyed out
    Posted 02-11-2015 22:39
    Hi Dirk,
    Do you see the Directory tree for the Media Manager? If so can you navigate to internal sources and select them?
    Nigel
  • 13.  RE: Cadbonite Media Manager greyed out
    Posted 02-12-2015 03:16
    nope thsts the problem. i will reimage the carbonite.again
  • 14.  RE: Cadbonite Media Manager greyed out
    Posted 02-12-2015 03:18
    that seems a little much.
    install team viewer and then email me the connection -- I am still up
    loreilly@rossvideo.com
