  • 1.  How to remove the (FSFC) display from the Multiviewer
    Posted 07-18-2013 20:52
    Les or Nigel,
    You mentioned in an earlier post that it is possible to remove the (FSFC) from the multiviewer UMD labels. I can't find how to do this. Can you help?
    Thanks,
    Jeff
  • 2.  RE: How to remove the (FSFC) display from the Multiviewer
    Posted 07-19-2013 01:42
    Hi Jeff,
    If you have version 7.2, you can turn it off in the multiviewer config. There are two places:
    1. In Dashboard, open the Configuration slot, go to the MultiViewers tab, select the multiviewer, and set FS Label to Off.
    2. On the panel, go to the System menu, then MultiView, then press NEXT twice and set FSLBL to Off.
    James.
  • 3.  RE: How to remove the (FSFC) display from the Multiviewer
    Posted 07-19-2013 17:47
    Thanks James!!!
    Jeffrey obviously you have been given your answer. This is really what we were aiming for with the launch of the Community. Seeing it grow and have users sharing and answering each others questions really does make this a great place to share ideas.
    It is great to see this!! Sorry we were not able to beat James to the response :)
  • 4.  RE: How to remove the (FSFC) display from the Multiviewer
    Posted 07-19-2013 18:09
    Yes, thanks James, that worked great. I saw that button in the Dashboard configuration tab, but didn't realize it was for the (FSFC) text.
