  • 1.  Reset MLE Store
    Posted 05-30-2012 21:55
    Is it possible to reset/clear an MLE memory?
  • 2.  RE: Reset MLE Store
    Posted 05-31-2012 18:57
    in a "round about method"
    You can save your setup to USB. Then on the usb delete the Memory you don't want. Then you can load that usb memory set back into the system.
    Also you can just save over it.
  • 3.  RE: Reset MLE Store
    Posted 06-05-2012 03:41
    Thats a cool way to do that. Thanks!
