Linked to the "Protocol" item under the "Linear Editors" part of the "Interface List" for the Carbonite switcher is a pdf document named GVG100-Commands(4802DR-401-02).pdf.
The document claims the switcher can accept GVG100 commands using "LUA" commands via Telnet or serial connection but never defines "LUA" and provides only one sample command that I can not duplicate.
I can successfully Telnet into the switcher and get the GVG100> prompt, but I can't go any further. Can you please update the documentation to define what "LUA" is and provide at least a few example commands.
Page 3 provides a command 'example' of "05 01 CC 50 14 05". When I try this command at the GVG100> prompt I get an error returned. When I try "injectGVG100command(05 01 CC 50 14 05)" I get the same error. How exactly should I enter a command?
I have the 'Model 100 Video Switcher Serial Interface Protocol" manual so I know how to build the command blocks. I prefer to use the Telnet interface rather than the serial. I just need a few examples to get me going.
